hikashop doesn't load product images
14 years 10 months ago #36060 by nicolas
1. and 2.
Go in the menu Display->content menus, edit your menus with the id 113 and 114 and disable the associated module you have. Actually, you have a products listing module associated to a products listing. So you see both at the same time...
3.
Go in the menu Display->content menus, edit your menu with the id 115 and change it's layout to list.
14 years 10 months ago #36172 by jackie
As always, you guys are amazing.
I've been searching the forums, and i can't seem to resolve my login issues.
I want a login on the Home page, which I have. I believe this is part of the Joomla template.
However, it seems to be conflicting with the Hikashop login. Even after you login on the Home page, you still need to login to purchase items. When I do that, the login box will not go away, and i cannot proceed to checkout. Before logging in:
jacquelinebejma.com/joomla16/index.php/c.../checkout?Itemid=101
After logging in:
jacquelinebejma.com/joomla16/index.php/c...ep/step-1?Itemid=101
There is also no "continue" or "checkout" button displaying.
I've configured the mini cart and rearranged the checkout workflow, but that doesn't seem to help.
Attached is how the checkout is configured:
14 years 10 months ago #36215 by nicolas
I tried but it's working fine on my end on your website.
I can login via joomla and hikashop sees me as logged in.
I also get the continue or checkout buttons.
14 years 10 months ago #36267 by jackie
Hmmm...how were you able to login? What username and password did you use?
This is the last thing I need to fix on the site, and I am anxious to get it done!
Thanks, as always, for your great help!
14 years 10 months ago #36268 by jackie
And, the only time I see the Proceed to Checkout or Continue Shopping buttons are for a second when you add to the cart. AFter that, there is no place to go to the shopping cart.
14 years 10 months ago #36307 by jackie
I've been working on this all day. I just realized that only the Admin username and password work on the frontend. Any other user can't login - the page just refreshes to the login page.
I've found this:
jacquelinebejma.com/joomla16/index.php?option=com_users&view=registration redirects to jacquelinebejma.com/joomla16/ind ... view=login, but that doesn't explain why admin works on the frontend.
Also, when logged in as admin, i get access to the site as desired, get to checkout, but when I get to "address" i can't enter anything - there is no form. When I click new, the page refreshes.
Thanks for your help through this...I'm heading to donate now - I've used more than my fair share of support.
14 years 10 months ago #36308 by nicolas
Yes, I had used the admin account to test that.
For the "new" button nor working for the address when you login that's because of your template's jquery library.
You should install and configure the extension jquery easy:
extensions.joomla.org/extensions/core-en...ements/scripts/18327
Regarding the add to cart popup not working properly when not logged in, that's really strange. Could you try to deactivate the SEF ? That might help solve the problem.
14 years 10 months ago #36312 by jackie
SEF is off. I will try installing this extension.
thank you, thank you, thank you.
14 years 10 months ago #36333 by nicolas
SEF is still on on your website.
14 years 10 months ago #36360 by jackie
SEF is off now - I had it off but switched it back on late last night because it was affecting all .png images. That is fixed now.
Installed jquery easy....still no pop up box for a new address during checkout.
Still unable to login to frontend with anything but admin credentials.
SEF off. URL rewriting off. Cacheing off. Users activated and enabled. User permissions set to registered. Joomla is up to date. Hikashop is up to date.
Any ideas?
14 years 10 months ago #36428 by nicolas
I see that you have the jquery easy plugin configured that's good.
You howver sitll have a javascript error caused by your image slider:
Uncaught TypeError: Property '$j' of object [object DOMWindow] is not a function
in the code:
var $j =
$j(function(){
$j("#faded").faded({
speed:500,//default 500,
crossfade: true,
autoplay: 5000,//default 5000,
autorestart:5000,//default 5000,
autopagination:false
You should either disable it or ask the support of your slider module/component for help on how to solve the problem. I believe that it's because they used a modified version of jquery and thus with the default jquery library used by jquery easy, their code does not work anymore.
14 years 10 months ago #36434 by jackie
Thanks - I'm in contact with the developer of the template and hopefully he finds a resolution.
What do you think about the admin access? I need public, registered users to be able to login to the site - it's not a site that is meant for the general public, aside from the homepage.
14 years 10 months ago #36463 by nicolas
I think that it's good like that. Is that your question ?
14 years 10 months ago #36491 by jackie
No.
The question is this:
Why can't a user login to the frontend of the site?
When any user (aside from admin) logs in, the page refreshes and prompts you to login again. From the backend, you can see that no one logged in.
14 years 10 months ago #36542 by nicolas
I'm not able to register on your website so I couldn't test with another login.
14 years 10 months ago #36559 by jackie
I know.
I don't want to allow registration online.
User login is:
username: jbejma@gmail.com
password: vintage
This user is activated and enabled. Has registered access.
14 years 10 months ago #36562 by nicolas
That's the email, not the username... The username for that user is: jbejma
I just tried and it works fine.
14 years 10 months ago #36563 by jackie
dear lord....i've obviously spent way too much time looking at this.
i am eternally grateful for all of your help. thank you SO much.
Time to create page: 0.140 seconds
